Zywall SecuExtender can't auto reconnection
vodovodo
vodovodo Posts: 2
image  Freshman Member
edited April 2021 in Security
My hardware is Zywall USG110 series with config by using SSL VPN type to access the system
I already have upgrade firmware USG110 to version 4.33(AAAA.0) and use SecuExtender 4.0.3.0 at client side.
I found when ISP lost signal and signal comeback, that SecuExtender can't automatic reconnected and need someone to click at "Connect" for re-establish, that my site have no human control on midnight for auto sending email report everyday.
Please advise how to config for automatic reconnected on SecuExtender software or have any patch in this case
  • vodovodo
    vodovodo Posts: 2
    So Thanks in your answer and support
    With hope the idea will be developed and add-in SecuExtender software as likely as others brand such as Sophos
