USG Flex 100 IKEv2 tunnel stability with iPhone
kelmi
kelmi Posts: 67
First Comment Friend Collector Eighth Anniversary
image  Ally Member
Want to share my experience with USG Flex 100 IKEv2 and LT2P/IPSec tunnels in practical usage. The configs what I have in USG are standard ones, I have not done any modifications to what the wizards give, while setting up the configs.
With iPhone and iPad having the latest iOS versions, clearly it seems to be so that L2TP tunnel is much more stable compared to IKEv2. IKEv2 tunnel is breaking with or without I’m using any application creating traffic between some 10min. While L2TP tunnel in practice is not breaking at all.
I would like ot ask experiences from other users? And if there is any tips how to change enhance the stability for IKEv2 tunnel as well via changing parameters in USG?
Regards
K
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,253
    image  Zyxel Employee
    edited October 2025 Answer ✓
    Hi @kelmi
    I did a local test with 5.40 firmware and iOS 26.0 but I didn't encounter this issue. The IKEv2 connection is kept over 10 minutes.
    May I know if this issue happened in the previous iOS version? Also, what's the logs of the IKEv2 connection?
    Update: Change the phase 2 proposal DH to none get better stable connection. But the VPN connection is still disconnect when the iPhone screen is locked. This is the iOS's limitation, need to make some change on iPhone.
    Zyxel Melen
  • Zyxel_Melen
    Hi @kelmi
    Zyxel Melen
