GS1920-24v2 restore configuration fails on classifier
After updating firmware from V4.70(ABMH.8) to V5.00(ABMH.1) on GS1920-24v2, the configuration restore failed on the following classifier line:
classifier "Allow Work DMZ" vlan 50 time-range Work hours
Recreating the classifier configuration on the switch (on V5.00(ABMH.1) firmware) and backing up the configuration generated the following identical classifier line:
This still failed to restore as a configuration. Why is the configuration backup generating a config that can't be restored?
Best Answers
Hi @gwinters
This issue is because the restoring process encountered an issue with the time-range profile name that includes a space. This issue has been addressed and will be fixed in the future firmware release.
Zyxel Melen0 -
Yes, this is a short-term solution for this case.
Zyxel Melen0
Hi @gwinters
I can replicate this issue and we are investigating on this now. I will update you once I get further information.
Zyxel Melen0 -
Hi @gwinters
Zyxel Melen0 -
Would the short-term solution be to remove the space from the time-range profile name?
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 196 Nebula Ideas
- 6.3K Security
- 481 USG FLEX H Series
- 313 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 450 News and Release
- 4.3K FAQ
- 93 Security Highlight
