redundant VPN connection (concentrator?)
We have a customer with a Zyxel Flex500 and two WAN connections in our part. There is another site with one internet connection. We would like to set up the VPN connection to work redundantly on our part, if the primary WAN connection is lost, it will automatically work on the second one. Is there a description for this? Unfortunately I couldn't find it.
So on the site with two WAN you want to setup the VPN gateway with setting My Address Domain Name / IPv4 to 0.0.0.0 then on the remote site setup for Peer Gateway Address with primary and secondary with fall back.
Unfortunately, this isn’t working.
ChatGPT says that there’s an “Enable backup Gateway” option in the VPN gateway settings, but I can’t find it.0 -
Are you using Nebula or standalone?
Should just be a case of this on the site with two WAN IP
and the other site
By the way USG FLEX 100HP does not have this feature. Peer Gateway address only has one input field. Is this a limitation and FLEX 100HP does not support failover vpn?
Как настроить failover vpn, если есть USG Flex 100HP с одной стороны и USG ATP200 с другой стороны? Оба используют по два провайдера. USG Flex 100HP нет поля для ввода второго Peer Gateway.
For H series route-based VPN, you will need to: (2X2 & 1X2 scenario)
- Create the site-to-site VPN for each interface first.
- Navigate to Network > Interface > Trunk page to create a new trunk profile for the VTI interface. One is active and another is passive.
This will make the VPN traffic pass only one VTI interface only, and failover when the primary down.
For H series policy-based VPN (1X2 scenario), the method is like what PeterUK mentioned, but it requires firmware support. Additionally, the next firmware, V1.36, will support this scenario for policy-based VPN.
Zyxel Melen0 -
Update:
Firmware V1.36 has been released.
4. [Enhancement] Support secondary peer gateway for VPN failover and fallback.
Zyxel Melen1
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
