Internal DNS
I have a quick question about usg40w router, fw 4.33. I setup a dns entry for the router, as :
router.fqdn : xx.xx.x.xx
Ma computer has the router's IP as only DNS server.
When I test the IP resolution of the router, sometimes I got router.fqdn and sometimes myrouter.fqdn
I couldn't find any occurence of the name myrouter in my config. This is a bit confusing, where does that name come from and why it resolv randomly router/myrouter?
Thanks,
Davy
Can share screenshot of your USG DNS setting and PC resolution result?
For sur, here is the screenshots as asked.
The DNS cache on your PC is belonging to A record.
So it means your PC has sent DNS request(myrouter.XXXX.XXX)to USG DNS.
When USG is a DNS server role, it will check TPR record and itself DNS cache first.
If without record exist, then will send request to external DNS server.
You can enter this command to show exist DNS cache exist on DNS server.
Router> show ip dns server cache
You can flush PC and USG DNS cache first and capture the packet to make sure how it happened.
CLI command to flush DNS cache: Router(config)# ip dns server cache-flush
Thanks a lot for this information.
Davy
After USG setup domain name in System > Host Name.
DNS server will add a record automatically (e.g. myrouter.zyxelusg.com -> Interface IP)
It is for user can easier connecting to WebGUI by entered: https://myrouter.usg.com
If result IP not belonging to USG LAN interface, then this record is not reply by USG DNS server.
Thanks for that information.
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
