USG310 - AV - is it work?
I've never seen any logs with AV results.
What is your experience with AV? I think its not working at all.
I tried https://www.eicar.org/?page_id=3950 sample files and I can download them without any problems.
We are paying for AV Activated text in our zyxel panel or its working?
How can I check if its working? Should I set anything else to make it react on downloading virus files?
Hi @Przemek
Can you make sure your configuration on USG first?
(1) Create Anti-Virus profile
a. Enable EICAT test virus
b. Enable destroy infected file
(2) Apply Anti-Virus profile to policy control rule.
(3) And then go to download the test file from eicar.
Then PC still can download the file successfully, but the file is unable to unzip or content will replace as “0”. And USG will display log that destroyed the file.
Looks like rule on top PolicyControl make job:)
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
