Option to deactivate "Admin" user
mietz
mietz Posts: 7 image  Freshman Member
edited July 2024 in Switch Ideas
Since we can create other users with Privilege level 14, it would be nice if we could enable / disable the default "admin" account (From a privilege level 14 account).
2 votes
In Plan · Last Updated
The username of the default account "admin" can be changed on firmware version 4.90 or a newer version.
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,085 image  Zyxel Employee
    Hi @mietz,
    You can change the administrator account's username from "admin" to the name you prefer when the running firmware version is 4.90 or a newer version. Below is an example of GS1350 running the 4.90 firmware version.
    For the other switch model, please stay tuned on the category "switch new release."
    https://community.zyxel.com/en/categories/switch-news-and-release
    Zyxel Melen
  • p4nd4
    p4nd4 Posts: 2 image  Freshman Member
    Hi @Zyxel_Melen
    Is there any ETA for a Firmware providing this feature to XS1930 series?
    Best regards
  • Zyxel_Melen
    edited November 2025
    Hi @p4nd4
    Thank you for your inquiry about this feature for the XS1930 series.
    I'm still clarify with our team, and I will update the result here once I get further info. Thanks.
    Zyxel Melen
  • Zyxel_Melen
    Hi @p4nd4
    The current firmware for the XS1930 series has demonstrated solid stability and compatibility, so there is no urgent need for a new release at this stage.
    We will continue to maintain the product based on its actual operational status.
    Zyxel Melen
  • p4nd4
    Hi @Zyxel_Melen
    Thank you for the information.
    It's good to hear that the XS1930 series will continue to be maintained / supported. This at least opens up the possibility that this feature could be implemented in a future firmware update.
    Best regards
