FLEX 200H - loss of 2.5GB
I converted from a FLEX 500 to the FLEX 200H to gain the 2.5Gb network speed needed. I've had many issues with the 200H talking to the XMG1915 which drives the WBE530 APs. Nothing I've found allows for VPNs across this network - only LAN1 works.
Additionally, the FLEX 200H lost the 2.5Gh option on all LAN ports (3-8) post Update to v1.36(ABWV.0). Tried to revert to the older version and got the same
Has anyone seen this and know how to get the 2.5Gb back?
as listed here
USG FLEX 200H | USG FLEX Firewall - License & Spec | Zyxel Networks
Only port 1 & 2 are 2.5Gb the others are 1Gb
Which VPN can't access which network? Could you share some details about your setting?
Additionally, the FLEX 200H lost the 2.5Gh option on all LAN ports (3-8) post Update to v1.36(ABWV.0). Tried to revert to the older version and got the same Has anyone seen this and know how to get the 2.5Gb back?
USG FLEX 200H only provides port 1 & 2 that supports 2.5G. The other ports only support up to 1G. You can check our website for the device specific details.
Zyxel Melen0
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
