CLI command via Remote Configurator is NOT available
Hello everyone,
I tried to follow this guide:
So I logged in remotely via Remote Configurator:
in a pair of FlexH firewalls of mine and click here:
and also on a cheaper model:
Anyway I am NOT able to have the CLI working, neither on Edge:
Or Chrome:
The only way to use the web CLI is when I am connected on the same subnet or having a static public IP that I can reach from the rest of the world.
So… am I forced to go onsite or have a PC remote connection or a VPN user to login on the firewall?
Is there a way to have it working properly also via Remote Configurator via Nebula?
The only option that I know I can use remotely (when I have no man onsite, no PC available and possible VPN) is to set a Policy:
to open a specific port for remote connection to ZyWALL, but this means that I'm forced to have a static public IP available and opening ports is NOT always possible (e.g. health organizations where to place a secondary network, under another ISP operator that filters some ports…).
I tried also this:
But it seems to have issues with some LTE (or other filtered) internet connections while Remote configurator works nicely.
Please let me know if it is a limitation by design.
Hi @GiuseppeR
The first issue is because the remote configurator only mapping HTTPS port for web GUI. I will report to our product team for enhancement.
The second issue is because the ssh port is not allow on the H's security policy.
Zyxel Melen0 -
Hi @Zyxel_Melen
could I suggest also to add also a "logging to txt" export way on the web CLI?
Otherwise you have to use PuTTY over Remote SSH and it is not always available to install on every machine 😁
Hi @GiuseppeR
We currently can do this by some tricks.
- Access device's GUI via the remote configurator and login.
- Click the console button on device's GUI.
- Copy the port of the remote configurator URL and paste to the console tab. EX. remote configurator URL is "X.X.X.X:26309/", copy ":26309" to the console tab and go, then you will access the web console of your firewall.
In addition, this trick can only work after clicking the console button.
Zyxel Melen0
- 234 Nebula Ideas
- 6.7K Security
- 723 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
