Zyxel XS1930-12HP: Some Ports Power PoE but Never Establish Link-Up
xfzhao
xfzhao Posts: 2 image  Freshman Member
I have an issue with my Zyxel XS1930-12HP where two of the ports are not working properly, and I could use some help identifying the cause and how to fix it.
Problem Description:
Two of the Ethernet ports do not establish a link when a device is connected — the link never goes up. However, when I connect a PoE device, the port still provides power but never negotiates data link up.
I am currently running the latest firmware version V4.80(ABQF.4) and the hardware version is V1.2.
This issue has been reproducible since earlier firmware versions. What seems to trigger the problem is when a port repeatedly goes link-up/link-down due to frequently changing connected devices. After some cycles, that port loses the ability to establish a link and stays dead even after a reboot.
In older firmware versions, I could recover the port by holding the Restore button for 30 seconds, after which the port would work again. But now even after a 30-second Restore, the port still does not work.
There is one unusual behavior: after power-cycling the switch (unplug and re-plug power), during the boot sequence the affected port can briefly link up, but once the switch has fully booted, the port stops working again and cannot be used for network traffic.
What is the problem, and how can I fix it so my switch is working properly again?
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,297
    image  Zyxel Employee
    edited March 5 Answer ✓
    Hi @xfzhao
    This is a known issue and we can provide you a date code firmware to fix it. I will provide it to you via private message.
    Update:
    Since no feedback from xfzhao, we assume the issue is resolved, and this fix will be included in the next firmware release.
    Zyxel Melen
  • Zyxel_Melen
    Hi @xfzhao
    Update:
    Zyxel Melen
  • dbalazs
    dbalazs Posts: 2
    I have a very similar issue XS1930-10 (no PoE): the link is not established in certain port and sometimes the reboot of the switch solve it, sometimes not.
    At the moment I can not exclude the HW problem but if you recognize it as the mentioned "known issue" then please provide the beta firmware.
    I will contact you in private channel as it was requested earlier.
    Identifications:
    System Name
    System Location
    XS1930
    Boot Version
    ZyNOS F/W Version
    V1.00 | 08/26/2019
    V4.80(ABQE.4) | 08/23/2024
    System Time
    System Uptime
    05/19/2026 14:44:43
    000 days,00 hours,06 mins,03 secs
    Serial Number
    Hardware Version
    xxx
    V1.2
  • dbalazs
    dbalazs Posts: 2
    update for the previous post, if somebody review this thread:
    Zyxel confirmed the hardware issue of the switch and replaced it within its Limited lifetime warranty.
  • pw123
    pw123 Posts: 7
    edited June 2
    I have seen the same issue. I would like to try the beta firmware to see if it can be resolved.
    My switch is Zyxel XS1930-12HP
    System Name
    System Location
    XS1930
    Boot Version
    ZyNOS F/W Version
    V1.00 | 08/26/2019
    V4.80(ABQF.4) | 08/23/2024
    System Time
    System Uptime
    06/02/2026 14:04:56
    001 days,03 hours,28 mins,04 secs
    Serial Number
    Hardware Version
    V1.2
    Thanks.
