Enable/Disable Global zone forwarder is not that good
I'm thinking it might be when a listed this idea but it was not what I was hoping it be
Remove AUTO added DNS as forwarder — Zyxel Community
This is how I want the FLEX H to be
this is what I want to stop from DHCP client interfaces
Yes there is a way to remove the DNS option from DHCP discover/request but really just wanted a simple way USG does not add then to the Global zone forwarder.
What does not having any Global zone forwarder do you might ask? it allows the USG to be a DNS server to do the lookups by going to root server then (TLD) DNS server till it gets to the answer.
Hi @PeterUK
After checking, this still needs the USG FLEX H not request the DNS option in the DHCP discover/request. Let me help share this requirement with our product team. This might be adding an option that disable DHCP request DNS option in each external interface setting.
Idea post:
Disable DNS server in global zone forwarder for USG FLEX H — Zyxel Community
Zyxel Melen1
Hi @PeterUK
Idea post:
Zyxel Melen1
- 242 Nebula Ideas
- 6.8K Security
- 779 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 526 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
