[USG Flex H] - Tailscale VPN - every reboot Default SNAT not working
Hello everyone,
every time that I reboot of my USG Flex 200HP, the Tailscale exit node not working anymore.
I've enabled the exit node from the Tailscale configuration, and enabled the Default SNAT rule. All works fine, until I reboot the firewall; by default this rule is enabled (reload the last setting) but seems not working anymore.
The first time that the firewall is rebooted, the Default SNAT is enabled (reload last configuration) and If I try to surfing the web, no pages are loaded neighter if I try to PING 8.8.8.8 no PING succedeed; if I disable the Default SNAT option —> save the config —> re-enable the option —> save the config, in this case all works fine, the PING eighter the surfing.
Thank you
Hi @Maverick87 ,
We have a fix ready for this issue, which will be included in the next official firmware release planned for July, as well as the weekly firmware update scheduled for next Thursday.
In the meantime, please continue using the workaround of disabling and re-enabling DNAT as you mentioned.
Zyxel_Judy
Hi @Zyxel_Judy,
Thank you, please prioritize if possible, as for now, is impossible to use the service.
Thank you
Hi @Maverick87 ,
Zyxel_Judy
Hi @Zyxel_Judy,
LOVE IT!!! Thankkk yoooouu!!
- 234 Nebula Ideas
- 6.7K Security
- 721 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
