GS1900-48HP last firmware version ?
madosoft739
madosoft739 Posts: 3
image  Freshman Member
Hi all,
I have a GS1900-48HP with firmware V2.60(ABTQ.0) | 02/25/2020 installed.
I already checked for the last version and found this one:
GS1900-48HPv2_2.90(ABTQ.1)C0
but I saw it's for GS1900-48HPv2.
Checking in the community I found an old 2024 post that refers to the EoL list for this type of switch but on that list I cannot find it.
My question is: is the v2_2.90(ABTQ.1)C0 the correct version for that type of switch ?
If not, where I can find the correct one ?
Thanks in advance for your help!
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,869
    image  Zyxel Employee
    Hi @madosoft739
    If your current firmware version is V2.60(ABTQ.0) | 02/25/2020, your device is a GS1900-48HPv2. You can visit the Download Library to download and install the latest firmware for your device.
    Zyxel_Judy
