Zywall 310 allow only one IP public FTP port
Why yes just setup the firewall to allow one source IP when you setup a address object for host of the IP.
thanks for your reply
i'm trying to allow FTP from external users but it's not working, can you help me ?
you can see attach the policy control and NTP rule ...
FTP TCP port 21
i've an error on the connection :
Statut : Connexion à x.x.x.x:21...
Statut : Connexion établie, attente du message d'accueil...
Statut : Serveur non sécurisé, celui-ci ne supporte pas FTP sur TLS.
Commande : USER FTP-User
Réponse : 331 Password required for User
Commande : PASS ********************
Réponse : 530 Login incorrect.
Erreur : Erreur critique : Impossible d'établir une connexion au serveur
For information ,with the Same rule (but with port 22) it's working in SFTP (SSH FTP)
it's a FTP on a synology
ty
Do you have ALG for FTP enabled with FTP transformations?
Your FTP logs show Login incorrect so traffic is getting to the FTP server.
Hi PeterUK
thanks for your reply but i'm sorry i don't know about ALG, what is it and where can i show this ? thanks
Its in the Zywall 310
Network > ALG
it allow the FTP traffic to work for other ports the FTP needs.
It might not help as your getting Login incorrect so check your user name and password.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
