Setup WAN Port to 1000MB
we have to set the speed of the WAN Port 1 on 1000 MB / sec and Full Duplex
With autonegotiation we have problems with streaming services on Internet an have to fix the speed to 1000 MB/s (1GB)
Via PuTTY cosole we can set the speed only to 10 oder 100, but not 1000 ?
Is there possible to fix the speed to 1000, and why ?
Auto should work fine to run at 1000Mb if link is dropping to 100Mb your cable might be bad.
The cable between router and Firewall is new, 0.5m and all my patchcables are cat.6a
The provider ask me to fix to 1000mb (not auto) because auto could be disturbing using with streaming services
the problems in my network are with differents equipments like PC, Laptops an apple devices
Previously I got the same problem and I reported the issue to Zyxel support.
They give me the date firmware which supports fix speed 1000.
Here are the commands for your reference.
P.S. I'm using ZyWALL 110 with firmware 4.33(AAAA.0)ITS-WK19-r88384
My FW is: V4.33(AAKY.0) / 2019-01-09 17:34:25
but with this FW speed 1000 is not possible
Hi @MarcelG
Here is the firmware download link, ftp://ftp2.zyxel.com/USG60/firmware/433AAKY0ITS-WK19-r88384.zip
Please have a check.
- 234 Nebula Ideas
- 6.7K Security
- 718 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 314 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
