[USG Flex H] - Summer thermal temperature
Maverick87
Maverick87 Posts: 553
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
image  Guru Member
edited June 29 in USG FLEX H Series
Hello everyone,
I've an 200HP firewall, and in the summer, the thermal temperature reach more or less 45-47 °C.
The temperature is measured via SNMP, I keep the current IC temp.
Can be a problem run the firewall at this temp? It's or can be critial?
Thank you
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,295
    image  Zyxel Employee
    Hi @Maverick87
    This is normal operating temperature. You don't need to worry.
    Zyxel Melen
  • Zyxel_Melen
    edited July 1 Answer ✓
    Hi @Maverick87
    The operating temperature specified in the datasheet refers to the ambient temperature. Additionally, the USG FLEX 200H's MTBF at 40°C ambient temperature is 306,768.409 hours.
    Zyxel Melen
    PeterUK Posts: 4,841
    image  Guru Member
    Its how hot my FLEX 200H gets and it fine
  • Zyxel_Melen
    Hi @Maverick87
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hi @Zyxel_Melen, @PeterUK
    Sound good.
    My value reading is done by the SNMP baseoid: 1.3.6.1.4.1.890.1.15.3.26.1.2.1.3.1
    Sometimes reach 50°C.
    My concern is due to the fact that the technical specifications say that the operating temperature is between 0 and 40°C
    Thank you
  • Zyxel_Melen
    Hi @Maverick87
    Zyxel Melen
