USG60 is increase Internet-Speed 70%
If I connect my PC direct on the router internet-speed si 489/491 up/donwnload
The USG60 switched between increase the speed to 157/188 mb/s
Content filter is disabled, whether IDP or antivirus on / off is no difference
If firewall is physically between an in Mode "OFF", internet speed is increase only 10-15% (418/454)
Could I optimize this ?
Can you try a speed test here
The first Speedtest is recommendet from my provider. I have a fibreoptic connection with 600/600 Up/Download
and the speedtest with firewall diasaled
when FW is enabled
With the speed your ISP set for you the Zwall 110 would have been a better choice.
Its odd that the firewall off it showing better speeds what firmware are you using? Is it the newest?
Is BWM (QoS) enabled?
as I understood that BWM is used for the connection of a VPN tunnel. Would this a speed advantage for my FW?
You recommend Zywall 110, there is one with "USG" and one without, Whats the difference ? There are other modells like 210, 310, ...
I have nearly the same Problem.
We have also configured VPNs. I have disabled the VPN for testing and got much better results.
Second you can disable WIFI and see what happens.
best regards
Wolfgang
I'installed VPN for a client one month ago, but actually is disabled. I havn't the Zywall with WIFI because I've a separted WIFI with POE and the Zywall is in the cellar.
Hi @MarcelG
The main difference is on UTM(Anti-Virus, Content Filter, Anti-Spam, IDP) features.
Can you send me your latest configuration file via private message. I test the performance on my lab to see if it is configuration issue or not.
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
