Hit count - security policy
mjr
mjr Posts: 42
First Comment Friend Collector Eighth Anniversary
image  Freshman Member
edited July 2024 in Security Ideas
Hello!
Maybe it is possible to add a "hit count" to the security policy rules, to see the activity of a specific rule.
BR, MJR
0 votes
Active · Last Updated
  • mjr
    mjr Posts: 42
    maybe it is possible to add a "reset hit count" to the security policy and routing
    PeterUK Posts: 4,751
    image  Guru Member
    edited August 1
    on FLEX H uOS models there is but likely the old ZLD may never get.
    if you need to reset the counter just disable and enable the rule
