Block WAN IP Address for 24 hours
JohnB1
JohnB1 Posts: 2 image  Freshman Member
If an IP attempts to access more than 30 different URLs within 60 seconds, and the majority return 404 or 401, block the IP for 24 hours.
2 votes
Active · Last Updated
  • Maverick87
    Maverick87 Posts: 509
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
    image  Guru Member
    Mmmm, probably in this situation, one think not work…
    This "rule" check the IP not the MAC Address; I can change the IP and it works again.
    PeterUK Posts: 4,818
    image  Guru Member
    The "Block WAN IP" is unclear? I'm think you want to block from LAN if a client tries 30 different URLs within 60 seconds and return 404 or 401 them block the client LAN IP?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,819
    image  Zyxel Employee
    Hi @JohnB1 ,
    Please clarify the scenario:
    1. Is the 30+ URL accessing within 60 seconds returns 404-401 pattern or block the IP in 24hours coming from a LAN client?
    2. If it's a LAN client, should the block apply to its internet access, intranet access, or both?
    3. What's the use case or scenario behind this request?
    Zyxel_Judy
