USG FLEX H Series - V1.39 not stable has some issues
PeterUK
PeterUK Posts: 4,737
image  Guru Member
edited July 27 in USG FLEX H Series
Not sure if its my config or if it need redoing but its not good.
I think there is one good thing about it which is real DMZ V1 now works like ZLD but the UI is slow give errors like when editing firewall rules
error code 10017
show object address-object fqdn wildcard IP192168500
which IP192168500 is not a fqdn!
remote VPN for users to use the internet now only works if firewall rule is from any to any when you normally do from zone remote_VPN to to zone WAN2
User-Defined Trunk not working correctly with routing rules
like you have
VLAN443 active
WAN2 passive or active
if you have a router rule
incoming LAN
next hop WAN2
if you remove WAN2 connection it goes out VLAN443
if Default Trunk is set then traffic stick to
router rule
incoming LAN
next hop WAN2
and fails if you remove WAN2 connection
And for address-objects for FQDN the IPv4 Cache List takes some time to load but Expire cache by TTL shows on in UI when off in config for a given FQDN
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,110
    image  Zyxel Employee
    Hi @PeterUK
    Thanks for reporting it. May I know if we can modify the first case, edit security policy "test2", to further check this issue?
    Zyxel Melen
    image  Guru Member
    edited July 28
    Hi
    yes you can modify the rule "test2" like change to deny
    My FLEX 200H seems to not have this issue so thinking the FLEX 700H is setup with many FQDN around 600 I think but not in use by policy control
    image  Guru Member
    edited August 1
    update on the remote VPN problem link to if user is set to a user so it does work if you do a rule from zone remote_VPN to zone WAN2 but user must be any however this only applies to the internet for VPN users where as before you select what users have access to the internet but LAN side can still be locked down by user by VPN.
    image  Guru Member
    Looking better with new firmware only a small bug to do with Expire cache by TTL shows on in UI when off in config for a given FQDN
  • Asgatlat
    Asgatlat Posts: 135
    First Comment Friend Collector Eighth Anniversary
    image  Ally Member
    My flex200h still say that 1.38 is the latest FW. Is that normal ?
    image  Guru Member
    Its to do with "Latest" and "Stable" so if you want it you can get it at https://portal.myzyxel.com/
    download other then the issues I was having it runs fine but if you do run into issues you can load the standby firewire.
  • Zyxel_Melen
    Hi @PeterUK
    The Expire cache by TTL display issue will be fixed in the next official firmware release.
    Zyxel Melen
