[USG Flex H] - Browse webserver from Mobile/Tablet
Maverick87
Maverick87 Posts: 508
Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate
image  Guru Member
Hello everyone,
I use Brave Browser on my iPhone 16 and a lenovo tablet 10" inch.
With iPhone and little screen seems that is very unusable, all are too little that is impossible to manage; instead with a tablet, the problem is that impossible to scroll down/up the left menu and the lists.
There is another browser that can I use? What is the required browser that is fully compatible?
Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,220
    image  Zyxel Employee
    Hi @Maverick87
    Since the USG FLEX H series recommended minimum screen resolution is 1366 x 768 pixels, it is not recommend using smart phone or Tablet to access web GUI. Additionally, different browsers get the same result.
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hi Melen,
    so the layout website is not responsive? If not, I open an idea to convert the site into a responsive mode.
    Thank you
  • Zyxel_Melen
    Hi @Maverick87
    H series supports RWD, but it has the limitation on the screen resolution.
    The idea post is created, and our team will monitor the comment and votes to evaluate this idea/requirement.
    USG Flex H support browse webserver from Mobile/Tablet — Zyxel Community
    Zyxel Melen
  • Maverick87
    image  Guru Member
    Hi @Zyxel_Melen,
    If I try to browse the interface from the NCC center?
    Login into NCC —> Remote Configurator —> Login into the FW from the released IP.
    Can work from mobile/tablet?
    Thank you
