Del dhcp request domain-name-servers does not always work
PeterUK
PeterUK Posts: 4,833
image  Guru Member
edited August 16 in USG FLEX H Series
USG FLEX 200H V1.39(ABWV.0)
So I get the idea you don't want to change the DHCP client Discover/Request and for good reason but do like: turns out it does remove domain-name-servers from Discover/Request
del vrf main interface ethernet Backup_4G ipv4 dhcp request domain-name-servers
thereby removing it in config to show
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "subnet-mask"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "broadcast-address"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "time-offset"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "routers"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "domain-name"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "domain-search"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "host-name"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "nis-domain"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "nis-servers"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "ntp-servers"
/ vrf "main" interface ethernet "Backup_4G" ipv4 dhcp "request" "interface-mtu"
without
/ vrf "main" interface vlan "Backup_4G" ipv4 dhcp "request" "domain-name-servers"
and when the offer/ack come back to not add it to the Global Zone Forwarder but this does not happen in all cases likely due to the way offer/ack is done that the ignore domain-name-servers is added when it should not. the reason is Netgear add the domain-name-servers for offer/ack even if you did not ask for it
So here is attached is that case
  • Zyxel_Melen
    Zyxel_Melen Posts: 5,282
    image  Zyxel Employee
    Hi @PeterUK
    Seems like without / vrf "main" interface vlan "Backup_4G" ipv4 dhcp "request" "domain-name-servers", the firewall won't add this option in the DHCP discovery/request packet. Is there any issue or concern?
    Zyxel Melen
    image  Guru Member
    hi Melen
    The issue is I don't want to add any Global Zone Forwarder by any DHCP interface just want the Default which is why I do
    which does remove the request domain-name-servers from the Discover/Request but some servers give the DNS in there offer/ack when not asked for in Discover/Request
    I'm hoping the option can be made better to really not add DNS to the Global Zone Forwarder
  • Zyxel_Melen
    Hi @PeterUK
    We have received your request, and the product team will evaluate it.
    I also create the idea post to record it:
    Zyxel Melen
    image  Guru Member
    edited September 1
    I think you missed the problem so to stop going round in circles the current way to make DHCP not ask for DNS works! but the DHCP server can ignore this and given you the DNS ANYWAY! causing it to be added to Global Zone Forwarder.
