USG20W-VPN - Where is the one-to-many NAT rule?
Hello community;
I've setup this firewall as a trivial home router, allocating all ports to the same interface and using them as a switch, and the WAN port connected to my ISP. Straightforward and no hassles but I noticed that I couldn't find any NAT or firewall rule that would allow my LAN to access the internet despite being able to do so.
I've looked under 'configuration → netwotk → NAT' and 'configuration → security policy → policy control' as the most likely places to hold such rule but didn't find any. Looked at all options afterwards but still didn't find it.
Exporting running-config and peeking into it also led me nowhere.
Am I missing something or is this rule sort of hardcoded and not configurable?
Running firmware V5.43(ABAR.0)
Paulo
I assume what you mean is SNAT the internal subnet to external interface/WAN IP.
The Zyxel Device automatically uses SNAT for traffic it routes from internal interfaces to
external interfaces, which is in Configuration > Network > Interface > Trunk > Default WAN Trunk > Advance > "Enable Default SNAT".Additionally, if you disable this function, you will need to setup routing policy and SNAT setting by yourself.
Zyxel Melen1
Zyxel Melen1
- 244 Nebula Ideas
- 6.9K Security
- 807 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
