NebulaFlex Switch XS1930 Series - V4.80 Patch 5 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 5,282
image  Zyxel Employee
edited October 6 in Switch New Release
Zyxel Switch XS1930 Series Release Note
May 2026
ZyNOS Firmware Version on all models
(Click Hyperlink to download the firmware directly)
Zyxel XS1930-10 - V4.80(ABQE.5)C0
Zyxel XS1930-12HP - V4.80(ABQF.5)C0
Zyxel XS1930-12F - V4.80(ABZV.5)C0
New Feature and Enhancements
1. 1.Optimized system stability and synchronization with Nebula to enhance overall device connectivity and management reliability.
Bug Fix
C=Cloud mode, S=Standalone mode
Bug fix C >S
1. [eITS # 250100440] DNS query fail cause cloud disconnect. V -
2. [eITS # 250302409] Fixed an issue that cannot connect to cloud due to uplink device MTU size too small V V
3. [eITS # 241200595] Fixed the issue that old MAC will not be deleted and be static after IP MAC move V V
4. [eITS # 250601371] Fixed an issue where ports Bug fix Nebula Standalone might fail to link up. V V
5. [eITS # 240301652] Fixed an issue where copper ports could become unresponsive after an ESD event. V V
6. [eITS # 251100621] Fixed an incorrect display issue in the IPv6 prefix setup due to an Index ID and interface mismatch. - V
7. [eITS # 251200652] Fixed a failure to configure media type. V -
8. [eITS # 240801706] Fixed an issue where end devices failed to obtain a DHCP IP address when IP Source Guard was enabled with static binding entries that matched the entries of DHCP static table on the DHCP server. V V
9. [eITS# 250200836, 241200613] Resolved an issue where a frozen PoE status triggered false alarm log entries. V V
Please refer to the Download Link for more details.
Zyxel Melen
  • Makksa42
    Makksa42 Posts: 5
    image  Freshman Member
    This is the same version as in May!
    PeterUK Posts: 4,833
    image  Guru Member
    edited September 3
    maybe a wrong number?
  • Zyxel_Melen
    Hi @Makksa42 & @PeterUK
    Since there was a bug fix didn't list in the release note, we created a new post to update it and also uploaded the corrected release note on our download library.
    Zyxel Melen
  • Radostin
    Radostin Posts: 4
    Hello, Melen, this post is still NOT corrected and XS1930-10's firmware version is the same from May.
    Please, modify this announcement to reflect real changes, because it is misleading.
    Neither attached here XS1930-10 package, nor the one in the "Download library" contain a firmware release from September.
    There is no logic in "September Firmware Release" newsflash to hold the exact same package of May/22.05.2026. Where is the actual September release ?
    Thank you !
  • Radostin
    Radostin Posts: 4
    Please, modify this announcement to reflect real changes, because it is misleading and there is NO firmware version from September in here.
    Neither attached here XS1930-10 package, nor the one in the "Download library" contain a firmware release from September. There is no point and logic in a "Firmware Release" news flash, when it doesn't hold an actual new release.
    Thank you !
  • Zyxel_Melen
    Hi @Radostin
    Thank you for raising this, and I'm sorry for the confusion.
    The September date refers to the new package we published, not to a new firmware build. The package contains the firmware file together with the release note. The original release note was missing a bug fix, so we re-uploaded the package with a revised release note. The firmware itself was not changed, so the version number remains V4.80 Patch 5, the same as the May release.
    I understand the announcement title and date made it look like a new firmware was released, and I have updated the post to make this clearer. Thanks again for your feedback.
    Zyxel Melen
