809 Error/Tunnel Swapping with IKEv2
Hi there,
we are currently running Client2Site Tunnels over IKEv2 using the integrated Windows 10 VPN Client which works fine for the most Part.
But whenever I change something on the IKEv2 Tunnel (for example IP Range) I get 809 Errors from the Windows Clients (iOS works fine) and have to reboot the firewall to make it work again.
From the USG logs it looks like the Client wants to connect to the wrong Tunnel.
Is there any way to avoid/fix this without rebooting the firewall??
I´ll try this next time. Thanks.
But this isnt only related to the Windows Client.
Greenbow produced the same kind of Error.
I think the Problem is the Firewall.
Maybe to many VPN Gateways?
Its an USG 310 BTW.
Hi @WiSy
In this case, you can click “Reset IKE” to clear related SA on TGB client before you establish new connection.
If the TGB client still goes to wrong tunnel, please send me the TGB console log via private message.
TGB console(Tools > Console)
TGB console
hello,
we are 7 years further, but I got exactly the same problem with Windows 11 native VPN-Client and Zyxel ATP500 (not nebula). The suggested solution (Set SplitTunneling = false) does not work.0
- 234 Nebula Ideas
- 6.7K Security
- 726 USG FLEX H Series
- 372 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 318 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
