802.1x security setting
Gogocar
Gogocar image  Freshman Member
edited May 2024 in Wireless
I want to set up the 802.1x security profile with AD server authentication, but it didn't work after I set up.
After I changed the "Radius Server Type" to internal, it worked correctly.
What's the difference between internal and external?
If I used an external server for authentication, it should be selected to "external", right?
