Reference counter 0 when its in use
USG FLEX 700H V1.40(ABZI.0)
Likely linked to this
https://community.zyxel.com/en/discussion/33759/ui-slow-and-fast-in-places#latest
All my address and address group Reference counter show 0 when in use
Hi @PeterUK
With the configuration you shared with us recently, we can see that the reference count is displayed correctly. When I apply the FQDN to a control policy, the reference count also increases.
To better assist you with your current configuration, please grant us access to your USG FLEX 700H so we can check it.
Zyxel_Judy
Hi @PeterUK,
You have a large number of FQDN objects, so we checked a random sample and found a couple of patterns:
Some of them aren’t referenced by any security policy or other feature at all, so a reference count of 0 for those is expected and correct.
Others are added to an object group (e.g., “Trusted_list”, “Trusted_list2”, “Trusted_list3”), and it’s the group — not the individual FQDN object — that’s selected in the security policy.Could you share a few specific FQDN objects that you’re using in a security policy or other feature directly, so we can dig into this more closely?
Zyxel_Judy
I'm not sure what you mean but a lot of them FQDN objects if not all of them are in use and its not just FQDN objects! I have a lot of smtp### IP ranges and they are all in use too and show Reference counter 0
Here is the “Trusted_list”, “Trusted_list2”, “Trusted_list3” being used
and it not just in a group thats a problem like this one
hope this helps
Even you logging in from a given IP shows Reference counter 0
Hi @PeterUK,
Thank you for the detailed information. We will check it and update you here as soon as we have any findings.
Zyxel_Judy
Hi @PeterUK,
Thank you for confirming via private message that the reference = 0 issue is gone, and that menu/page loading has greatly improved as well.
This fix will also be merged into the next official firmware version.
Zyxel_Judy
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 332 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
