i am looking for the right firewall model
Best Answers
The UGS60 only has 5 SSL VPN or 40 IPSec VPN without Subscription and 20 SSL VPN with a Subscription.
A ZyWALL_110 has 25 SSL VPN without Subscription and the new ZyWALL VPN100 which will likely replace that has 30.
So the USG60 if using IPSec VPN will be fine right out the box but if you plan on using the SSL VPN you need a Subscription.
6
6 -
thanks for your help!
Hi @MGutjahr ,
Welcome to Zyxel Community. 😎
You can refer to local representative if you require further assistance.
Where to Buy:
thanks for information, our distributor is ingram micro ;-)
2
- 234 Nebula Ideas
- 6.7K Security
- 706 USG FLEX H Series
- 369 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 313 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
