Config VPN CLI
I would like to know the command to change the VPN Peer primary Gateway Address . I need to change the gateway IP on many routers with a script but cannot find the right command in the CLI manual.
Thanks,
Davy
The cli as below,
configure terminal
isakmp policy [VPNGateway name]
peer-ip [Peer primary Gateway Address] 0.0.0.0
exit
write
Let us know if you need any help.😀
Thanks for the answer. With this command I can enter in VPN_connection profile but it is not working for VPN Gateway profile, I have this error when I try to call the VPN Gateway profile :
% v2 -> v1policy name: vpn_gateway_msfch
retval = -18006
ERROR: setting failed!
Okay, this is strange, I did :
configure terminal
isakmp policy Test
It created a new VPNGateway named "test".
But when I try to call my already setup VPNGateway it failed, but I can call the "test" one without any problem.
Can you try it again via SSH access without script? Input CLI one by one.
Will it have error if you type “isakmp policy vpn_gateway_msfch”
Ok I did all my test with a putty ssh session.
I still have the error when I try to do :
“isakmp policy vpn_gateway_msfch"
I tried to disable the gateway and disable both VPN attached to it and I have the same error
Router(config)# isakmp policy vpn_gateway_msfch % v2 -> v1 policy name: vpn_gateway_msfch retval = -18006 ERROR: setting failed! Router(config)#
Hi @IT_Field_Support ,
Just noticed the error message “% v2 -> v1”.
If VPN tunnel is IKEv2, the CLI is ikev2
You can try it again with cli below,
configure terminal
ikev2 policy [VPNGateway name]
exit
write
Perfect !
Thanks a lot !
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
