Packet flow explore for main route unknown
PeterUK
PeterUK Posts: 4,724
image  Guru Member
edited April 2021 in Security
ZyXEL VPN300 V10.02(ABFC.1)
I have a backup 4G dongle and I get in main route this I think it might be happening when the 4G renews the IP and adds another unknown to the list, it does not seem to be causing any problems however.
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,590
    image  Zyxel Employee
    Hi @PeterUK
    From the screenshot, the cellular interface gateway is 192.168.3.1, and the VPN300 interface GE6 IP/subnet is 192.168.3.1/24 by default.
    It looks like it was caused by subnet confliction. Can you change interface GE6 IP and try it again?
    image  Guru Member
    GE6 was already changed to 192.168.252.1/255.255.254.0.
  • Zyxel_Cooldia
    Hi @PeterUK ,
    Which 4G dongle are you using ? Can you send me your configuration file via private message. I would like to do some test based on your configuration file.
    image  Guru Member
    Just to update whats showing in Packet flow explore for main route now
    image  Guru Member
    Router> show ip route
    Flags: A - Activated route, S - Static route, C - directly Connected
          O - OSPF derived, R - RIP derived, B - BGP derived, G - selected Gateway
          ! - reject, H - Black hole, L - Loop
    IP Address/Netmask   Gateway         IFace          Metric   Flags   Persist
    0.0.0.0/0            192.168.3.1     cellular1      0        AS      -
    0.0.0.0/0            192.168.3.1     unknown        0        AS      -
    0.0.0.0/0            192.168.44.1    vlan443        0        ASG     -
    0.0.0.0/0            0.0.0.0         usb0           0        S       -
    127.0.0.0/8          0.0.0.0         lo             0        ACG     -
    127.255.255.76/30    0.0.0.0         br0            0        ACG     -
    127.255.255.80/30    0.0.0.0         br1            0        ACG     -
    192.168.2.0/24       0.0.0.0         ge5            0        ACG     -
    192.168.3.0/24       0.0.0.0         cellular1      0        ACG     -
    192.168.44.0/29      0.0.0.0         vlan443        0        ACG     -
    192.168.53.0/28      0.0.0.0         vlan53         0        ACG     -
    192.168.247.0/24     192.168.255.202 ge3            0        ASG     -
    192.168.252.0/23     0.0.0.0         ge6            0        ACG     -
    192.168.255.48/28    0.0.0.0         vlan18         0        ACG     -
    192.168.255.192/26   0.0.0.0         ge3            0        ACG     -
    image  Guru Member
    Just wanted to update this as it was fixed with 10.02(ABFC.2)ITS-WK47-r90761 but the change to V4.35 the fix might have been lost as of testing with V4.35(ABFC.0)ITS-WK47-2020-01-02-1912000979D the unknowns are happening.
