If my device running on ZLD 4.60C0, how to upgrade it to ZLD4.60 P1?
To upgrade your firmware to the ZLD v4.60 patch 1, there are several methods that can achieve this purpose.
Method 1. Download the firmware from myZyxel portal and upgrade the firmware from LAN locally.
Step 1:
Login to myZyxel portal, after logging into the portal, you will see your registered device list in Device Management > My Devices.
Step 2:
Choose the model firmware you want to download, click the "Download" button.
Step 3:
After clicking on "Download" button, the portal will pop up the download page, click on the 4.60(xxxx.1) icon. Then the browser will start the download process.
Step 4:
Go to File Manager > Firmware Management. Click on the "Local Firmware" icon and upload the downloaded firmware from your local PC/laptop.
Method 2. Upgrade the device firmware by Cloud
Step 1:
Login to your device GUI by "admin" account, in the dashboard, check on the "Device Information" widget. If your firmware version is prior to 4.60 patch 1, there will be an icon which will bring you to the firmware upgrade page. Click on this icon and the GUI will bring you to the page File Manager > Firmware Management.
Step 2:
Click on the cloud firmware icon, after showing up the "What's New" information, click on the "Upgrade Now" button, then you will be able to start the cloud firmware upgrade process.
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
