Load Balancing Products
I'm looking for all the Zyxell Firewall products, that support the Trunk Load Balance between two ADSL connection provided by two different routers; the routers are connectable by RJ45 cables.
Any suggestion on which Firewall i should choose?
Thanks in advance for your help.
MikroBT,
You can consider USG FLEX 200 or ATP200.
Specs of USG FLEX series:
https://www.zyxel.com/products_services/USG-FLEX-Firewall-USG-FLEX-100/license-and-spec
Specs of ATP series:
https://www.zyxel.com/products_services/ATP-Firewall-ZyWALL-ATP100/license-and-spec
For Zyxel devices, load balancing settings can be found under Configuration > Interface > Trunk > Default WAN Trunk menu.
A Trunk interface supports 3 types of Load Balancing Algorithms;
1- Weighted Round Robin is for balancing traffic load between interfaces based on their respective weights. An interface with larger weight transmits more traffic than an interface with smaller weight.
2- Least Load First algorithm used for sending session traffics through the least utilized trunk member.
3- Spillover algorithm used for sending network traffics through to first member of the trunk until there’s enough traffic the second interface needs to be used.
May I ask what type of Trunk interface you need?
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
