USG60W – Maintenance – Packet Capture – ftp
I would like to capture packets and save them on an external destination.
If I activate the ftp option I get an error in the “Captured Packet Files” field. If I keep the default 10 I should enter 0. And if I enter 0 the requested minimum number is 1.
So, the question is, does the ftp option work at all?
Ikarus
Hi @Ikarus
The notification means your system without enough storage to save file.
But you still can ignore notification and save capture packets to USB storage or external FTP server.
Is any problem to save your file to external FTP server?
You may take a screenshot of your test result or drop private message to me for further check.
- 241 Nebula Ideas
- 6.8K Security
- 758 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
