How can i backup running config in a switch using ssh script?
[Deleted User]
[Deleted User] Posts: 0
Zyxel Certified Network Administrator - Switch
image  Freshman Member
edited August 2022 in Switch
I want to make backups from my switch configs, and i want to use an ubuntu machine with cron for this task, so i can automate it.
My switch is a XGS1930-28HP with firmware version 4.5(ABHS 7.1)
I want to use this command in my script to ssh to the switch:
sshpass -p "password" ssh -o StrictHostKeyChecking=no admin@SWITCH_IP COMMAND
My command would be show run, and then i wopuld capture it, and save it a in file.. but i cant use any command with this, because when i try to use it, the switch return me this error:
Received disconnect from SWITCH_IP port 22:2: invalid command run.
Disconnected from SWITCH_IP port 22
So, please help me, how can i automate taking backup from my switch configs?
Thanks.
