GS1920-24 & XGS2210-28 switches and a problem with visibility of Windows hosts
progbcp
progbcp image  Freshman Member
edited August 2022 in Switch
Hello. For a small LAN are used two switches XGS2210-28 (backbone) and GS1920-24.
The problem is that from time to time Windows hosts (Win10) don't see most of other hosts over the network (via Explorer). After rebooting the GS1920-24, most of the hosts become visible; after rebooting the XGS2210-28 — some more.
What could be the reason for this and how to fix it?
  • Zyxel_Jonas
    Zyxel_Jonas image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @progbcp,
    2. Hosts correctly ping.
    If the host still can ping each other, it means that the switch is forwarding traffic normally and the problem is more related to the application layer.
    When the issue happens, you may try to clear the cache or temp file instead of rebooting the switch.
    Jonas,
  • Zyxel_Jonas
    edited August 2021
    Hi @progbcp,
    Welcome to Zyxel Community!   :)
    I would like to clarify the information below to analyze the situation.
    1. Are the application running for a while and the problem just suddenly happen?
    2. When the host is not visible via explorer, could you still ping the host?
    3. May I know if there is a sequence of when the problem happens and after the switch is rebooted?
    Jonas,
  • progbcp
    Hi!
    1. What kind of application are we talking about?
    2. I'll check this point as soon as problem will repeat.
    3. I didn't notice a direct dependence, the problem happens about once a week.
  • Zyxel_Jonas
    Hi @progbcp,
    Thanks for the information.
    1. I mean the quote below, just would like to clarify the application you were using go well at the beginning and the problem just suddenly happens?
    2. Thanks, I'll wait for your reply.
    3. Ok, noted.
    Jonas,
  • progbcp
    1. Yeap, problem just happens.
  • Zyxel_Jonas
    Hi @progbcp,
    Jonas,
