Slow upload speed SSL VPN USG200 FLEX
I'm experiencing very slow upload speed on SSL VPN tunnel using the latest secuExtender client. USG200 FLEX is also with the latest firmware. Data: SSL VPN 36/3 Mbit/sec (down/up), IPsec over LTP2 55/19, maximum connection speed (no VPN) 60/20. Bad connection was reported by many client. What can you say about that? I can't believe this is the firewall performance, workaround? Best regards
Hello @Miao1994
Here is another user's problem like yours. If you would like to have better VPN throughput, you may use L2TP VPN connection
. https://community.zyxel.com/en/discussion/10756/atp800-ssl-vpn-is-slow
- 241 Nebula Ideas
- 6.8K Security
- 759 USG FLEX H Series
- 380 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 321 Service & License
- 520 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
