XMG3927-B50A Connect to FTTP (Full fibre)
I have a ZYXEL XMG3927-B50A connected to a FTTC setup with TalkTalk. My Zyxel then connects via (cat5e and cat6 cable) to 2 other routers as AP connection. My setup works great The parental control work via the Zyxel throughout my system and get great coverage/signal. Im due to change over to a Full Fibre Connection FTTP with TalkTalk, as I dont want to change much/anything in my system I still want to use my Zyxel as router only which will be connected to a Openreach modem I guess. What setting do I need to do/change to flick this over to the FTTP connection and still keep my system running as it is (with the extra 2 routers working as they are at the moment). I dont want to use the TalkTalk router at all if possible. Thank You
- 244 Nebula Ideas
- 6.9K Security
- 805 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 330 Service & License
- 540 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
