USG40 - Connect console port for CLI
Aleftau
Aleftau Posts: 3 image  Freshman Member
I have a Zyxel USG40.
In web administration console i mistakenly activated "Authenticate Client Certificates "in" System / WWW / service control ", and I can no longer log into the administration interface.
I'm trying to log into the CLI to manually disable this setting, but I don't know how:
- The console port is an ethernet connector and not an RS232 ?
- I connected an Ethernet / RS232 cable and connected with Hyper terminal (115200-8 bits-no parity-1 stop bit-no flowcontrl) but I do not see anything on the console, even when restarting the USG40 ?
However it seems to me that the connection works because when I send a character it seems to answer me with another character?
=> Can you tell me what I can do because I am really stuck!
Thank you,
Truly,
Gilles
Best Answers
  • anno_t34
    anno_t34 Posts: 12
    Friend Collector First Anniversary
    edited December 2021 Answer ✓
    Here are the serial settings for my zywall:
    Speed: 115200
    Data bits: 8
    Stop bits: 1
    Parity: None
    Flow control: XON/XOF
    After loggin in, if you have the credentials execute:
    configure terminal
    no ip http secure-server auth-client
    Don't close serial connection, but check the Web access. If everything is ok, execute "write" in the console terminal and exit the serial console connection.
    Regards,
    A.
    PS: for sure consult the CLI manual for your device and firmware.
  • anno_t34
    anno_t34 Posts: 12
    Aleftau said:
    Thank's a lot annoying_t34 for your answer.
    Do you know how is this cable broached ?
    You're welcome Aleftaugenichts!
    I don't, but:
    https://pinoutguide.com/Net/Cisco-Juiper-Zyxel_RJ45_pinout.shtml
    Good luck and regards!
    A.
  • anno_t34
    anno_t34 Posts: 12
    Speed: 115200
    Data bits: 8
    Stop bits: 1
    Parity: None
    configure terminal
    Regards,
    A.
  • Aleftau
    But it don't work for me : Not possible to connect my terminal (tera term for exemple) to the USG40
    I try with your config but the same (Xon / Xoff or None for flow control)
    I think I have a bad cable RJ45 / RS232 (the port cable is RJ45 on the USG40 !)
    -> But I don't know how to pinout the cable, and don't find documentation about this cable !?
    Best regards,
    Gilles
  • anno_t34
    anno_t34 Posts: 12
    I don't, but:
    A.
  • Aleftau
    Thank's a lot anno_t34, all is right now !!!
    Best regards
    Gilles
