GS-105B v3 power supply
Hi @Nippes,
Welcome to Zyxel Community!
The dimensions and polarity of the GS-105B v3 plug is 2.1/5.5mm, positive on center pin.
Hope it helps.Zyxel Melen1
Hi @Nippes,
Hope it helps.Zyxel Melen1 -
Yes it helps. In the meantime I found an old Sega power supply with the same plug dimensions and it fit. I cut the cable, now knowing the polarity connected it to a USB plug and it works. Thank you.
- 3K Nebula
- 232 Nebula Ideas
- 132 Nebula Status and Incidents
- 6.7K Security
- 691 USG FLEX H Series
- 365 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 312 Service & License
- 505 News and Release
- 97 Security Advisories
- 5.1K FAQ
- 89 About Community
- 112 Security Highlight
