Using USG Flex 100W on Verizon FIOS. Should Verizon router be removed?
Jim43
Jim43 Posts: 2 image  Freshman Member
edited February 2022 in Security
I want to be able to manage my own firewall and first thought I would install Zyxel firewall after Verizon's. Should I just take Verizon router out of the loop and plug USG Flex 100W directly into the Verizon ONT? And will this entail a conversation with Verizon?
  • mMontana
    mMontana Posts: 1,514
    image  Guru Member
    IMVHO if you're willing to remove the router, the conversation with Verizon should start before removing the device or configuring the USG Flex 100W to replace it.
  • Jim43
    Thanks mMontana. Good advice.
