Why two default SSID profiles per radio for NWA210AX
Terry_D
Terry_D Posts: 1 image  Freshman Member
edited May 2024 in Wireless
Trying to understand why this is so.  The default config of a new NWA210AX access point has two MBSSID profiles for each radio. Each profile is the same SSID and same parameters.  A Wifi scan shows the 2.4Ghz SSID appearing on two different MAC addresses and the same SSID appearing on the 5Ghz radio also with two different MAC addresses. I assume there are two MAC addresses on each radio because there are two profiles on each radio.  The question is:  WHY IS THIS THE DEFAULT and WHY ARE THERE TWO ??
  • Zyxel_Bella
    Zyxel_Bella Posts: 588
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    image  Zyxel Employee
    Hi @Terry_D
    Welcome to Zyxel community.
    Zyxel AP broadcast a default SSID named “Zyxel_XXXX” with last 4 letters of mac address.
    According to your description, do you see four MBSSIDs of Zyxel_XXXX and separate into two radios?
    Please correct me if any mis-understanding and provide a screenshot will be helpful for us to clarify.
    Thank you
    Regards,
    Bella
