Poe Functionality with Mikrotik Products
Hello, I have a switch ZyXEL GS1900-24EP-EU0101F and trying to use PoE ports to power up multiple Mikrotik devices (3x AP, 2x Routerboard, 1x Cube 60Ghz) and Mikrotik does not want to Power UP. Is this PoE working with Mikrotik products? Many thanks for any feedback or experience. Have a nice day.
GS1900-24EP supports 12 802.3at ports for a total of 170W as power budget.. Which are the letf-ones, looking at the switch from the front.Your devices which standard and class require?Did you connect the devices on the right group of ports?0
@shadownt,
May I know if you have connected to the correct port group?
Please provide the detailed model name if still does not work.
Hello, yes. Problem was in firmware. PoE showed Total Power 0. After firmware upgrade to the one, where GUI has an issue, problem with PoE disappeared.0
@shadownt,
Glad to know the issue is resolved, can you let me know which firmware version you used?0 -
Hello Chris. Problematic firmware was 2.60.4, we moved back to 2.70.0, but there is an issue with GUI. But at least Poe working properly.0
shadownt said:Problematic firmware was 2.60.4, we moved back to 2.70.0, but there is an issue with GUI. But at least Poe working properly.
Considering the issues reported with 2.70.0 and PoE (on other switches, if i recall correctly) this outcome seems pretty funny.And Zyxel started pubblication for firmware 2.7 Patch 3 for some of GS19x0 series...0
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
