how to configure PXE on Zyxel Switch (xs3800-28)?
Dear Zyxel and Community
The only DHCP option is the one with profile 82 that can be configured on the switch.
Is there a way to set up more DHCP options?
Possibly via CLI commands?
Is it possible to configure the DHCP option "PXE" on the XS3800-28?
best regards
best regards
Sorry for the dumb question: why use a switch as DHCP Server?
@Dashmir,
Our switch does not support PXE, since it needs the specific column on DHCP however, our USG series can support this scenario, will recommend using it.
- 234 Nebula Ideas
- 6.7K Security
- 724 USG FLEX H Series
- 371 Security Ideas
- 57 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
