Issue with VPN Connecting to Internal Devices from WAN Failover to LAN1
I think you are misunderstanding my issue. The client connects just fine and has no issues. I am not able to access resources on the internal lan once the authentication / connection is established. The logs show connection is fine the traffic is being blocked hence what my first post stated.PeterUK said:So that will be L2TP over IPSec? Can you check the setting in the made VPN for windows has “use default gateway on remote network” checked.
Control Panel\Network and Internet\Network Connections
Yes client can connect fine but if the option is not checked then it will not work.
Also check a zone is set for the VPN on zywall
For the above to do with a VPN problem the Source IP would have to be set for the VPN subnet normally a VPN subnet you set for the connecting client would be 192.168.x.xdcgtechnologies said:The error in logs is below:
Match default rule, DNAT Packet, DROP [count=2] - 166.x.x.x 192.x.x.x - Access Block0 -
Another thing is if you enable for routing"Use IPv4 Policy Route to Overwrite Direct Route"0
What are the parameters for the zone that needs to be set? Thank you.PeterUK said:Yes client can connect fine but if the option is not checked then it will not work.
Yes that is correct as I am pulling a different ip address on the 192.168.7.x as an example. Thank you.PeterUK said:
So I fixed it. It turns out under "VPN Connection". The checkbox next to "Use Policy Route to control dynamic IPSec rules" was checked. I unchecked it and everything started working as usual. That was causing all the traffic to be blocked. Thank you for help and sorry for the confusion.0
It be set in the VPN setting for Phase 2dcgtechnologies said:What are the parameters for the zone that needs to be set? Thank you.
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
