Firmware for vmg8825 b50b
REDMEN
REDMEN Posts: 1 image  Freshman Member
I am using your vmg8825b50b product with firmware 5.1.ablz.1_b10 and I have some problems with the stability of the system: it often does not allow the WIFI connection and I have to switch it off and on again. I found a version of the VMG8825-V517ABNY7CO product
Firmware Release Note
V5. 1 7 (AB N Y 7 C0
At your place:
July 14, 2021
Author:
Emily Chang
IF I TRY TO LOAD IT, IT TELLS ME THAT THE IMAGE IS NOT CORRECT. GIVE ME SOME TELLING WHERE I CAN DOWNLOAD VERSION 5.17. THANK YOU
REDMEN
  • IrineuRomanato
    IrineuRomanato Posts: 2
    Hello, I have the same problem.
    I´m trying to put the router in bridge mode, but does not work. Does not take an ip address from another router.
    My test is to use this router as my network and wifi extension.
