USG Flex 100 Problem with Content Filter, Signature Updates, etc... etc...
Greetings,
I am using the User Guide USG FLEX 100_V5.31.pdf to verify the settings. The unit is registered and licenses are valid:
The App-Patrol Signature update works, the Anti-Malware and IPS cannot be updated???
In Web Content Filter no matter what URL I enter I always get
when testing a URL:
The result is that users wait for every URL a long time (~3-6 seconds) before seeing a website because of "Action when Category Server is unavailable" = Pass.
How do we resolve these problems???
Other question: do we still need to add the server certificate to the PC's behind the UGS?
OK, got it to work, limited the Source IP to the LAN 2 subnet. L2TP/IPSec and Zywalll Device routing works.
First problem: ad a DNS server to system settings of your device.Second question: if you don't add the device certificate to the PCs, the "s" traffic between USG and computer (HTTPs, POPs, SMTPs, IMAPs) won't be considered valid from the operating system.0
Thanks. Set up the DNS as in https://support.zyxel.eu/hc/en-us/articles/360001390854-How-to-setup-DNS-on-a-USG, no changes. Does anuone have the FQDN for the update servers and the content filter category server?
Seems to be a similar problem as this one: https://community.zyxel.com/en/discussion/2519/no-default-dns-for-wan1-on-usg40
Did you checked if your device is correcly resolving names via the interface?stepgilb said:Thanks. Set up the DNS as in https://support.zyxel.eu/hc/en-us/articles/360001390854-How-to-setup-DNS-on-a-USG, no changes. Does anyone have the FQDN for the update servers and the content filter category server?Maintenance -> Diagnostic -> Network Tool (NSLookup IPv4)
Just a moment ago, it is not resolving host names and I am not able to ping anything on the wan interface like the 7590 Fritzbox DNS server 192.168.178.1. The lan1 and 2 IP's are pingable (192.168.2.1 and 1.1). Looks to me like traffic is being blocked. I also tried pings using the CLI, same result. To get L2TP-IPSEC to work I had to add an additional NAT rule for the Outside (FB WAN address), maybe that's the problem?
Hi @stepgilb,
Welcome to Zyxel Community.
We may need to check if it is routing issue or DNS resolve issue.
Could you please draw a brief network topology with interface IP?
(Mask last octet on public IP)0 -
Thanks! L2TP/IPSEC is working perfectly, LAN 2 PCs 100% OK network wise, also concerning DNS
This is ping to one of the Telekom DNS Servers which works fine on LAN 2 but not here:
A ping to the FB Gateway and DNS Server does not work (on LAN 2 it does):
- 244 Nebula Ideas
- 6.9K Security
- 799 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
