USG 200 lan1 and lan2 communication
Hello everyone,
on a USG 200 i've created 2 lan on 2 different ports,
P1: 192.168.2.0/24
P2: 10.0.0.0/24
Now, I need them to communicate, for a collaboration between the two offices.
I've added in security policies two active rules:
Lan1 --> Lan2 any - any - any - any - allow
Lan2 --> Lan1 any - any - any - any - allow.
But the two LANS seems not to communicate.
Can someone help me, please?
Thanks in advance.
P1: 192.168.2.0/24
P2: 10.0.0.0/24
Thanks in advance.
Best Answers
Is in routing
unchecked?Use IPv4 Policy Route to Overwrite Direct Route 1 -
Having it unchecked will solve the problem and allow Direct Route without making routing rules. So it this solved or not?
Is in routing
thank you PeterUK for your answer, it was unchecked!0
I've done a NAT 1:1 on all the interested addresses (only five) as a workaround. This eve, after the office gone empty, I'll try the solution. Even if it was already unchecked.
- 241 Nebula Ideas
- 6.8K Security
- 760 USG FLEX H Series
- 381 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 521 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
