How to Connect USG700 to USG310 With Lan cable
Hi @NAZ4E,
Thanks for your sharing, You have to add rules to allow traffic.
For FW-1, src:Z_TPC-to-SPK dst: lan allow
For FW-2, src:Z_SPK-to-TPC dst: lan allow
Please kindly check and look forward to your feedback.
Thank you
Hi @NAZ4E,
Please kindly ensure you have routing on both firewalls .(USG310:172.16.1.0/24 next-hop 172.16.99.1)(Flex700: 192.168.5.0/24 next-hop 172.16.99.2)
Then you can connect to FLEX and USG at both sites.
Thank you
Kevin0 -
yes,i did it.but i can't ping 172.16.99.1 to 172.16.99.2 or 172.16.99.2 to 172.16.99.1
GE0/12 and GE0/8 Config interface type internal or external?
Hi @NAZ4E,
Please choose interface type "internal" for 172.16.99.0/30.
kindly share your configuration files by private messages.
I will do the check as well.
Thank you
Kevin0 -
Ok. I did it. but Can't Ping0 -
To ping each interfaces you need a rule from Z_TPC-to-SPK to Zywall and from Z_SPK-to-TPC to Zywall for ICMP.
Remove the static route rule
Then you need a routing rule.
Incoming LAN
Source address 192.168.5.0/24
destination address 172.16.1.0/24
next hop gateway 172.16.99.1
SNAT none
on the other side
Incoming LAN
Source address 172.16.1.0/24
destination address 192.168.5.0/24
next hop gateway 172.16.99.2
SNAT none
Then firewall rule
from LAN to Z_TPC-to-SPK and from LAN to Z_SPK-to-TPC.
ok. i configuration follow with you but can't conneted.
Hi @NAZ4E
I feel a little confuse, because the screenshots are not matched with your topology.
Please share the configuration files by private message
And kindly describe what is your purpose? (what IP address should be accessed from X.X.X.X) It will be clear.
Thank you
I want the two buildings to be connected.
TPC building can access time attendance and SPK building can access File Server.
Hi @NAZ4E,
Thank you
- 235 Nebula Ideas
- 6.7K Security
- 734 USG FLEX H Series
- 375 Security Ideas
- 58 Wireless Ideas
- 7.1K Consumer Product
- 319 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 117 Security Highlight
