Ideas selecting Radio settings: NWA5123-AC-HD, WAC500H and WAX510D APs
Rimfire
Rimfire Posts: 20 image  Freshman Member
edited May 2024 in Wireless
Hi
These APs are ZyWALL 110 controlled. What do you suggest for radio settings when having this type of mixed AP enviroment?
6pcs NWA5123-AC-HD
2pcs WAC500H
1pcs WAX510D (will setup this on next week)
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,585 image  Zyxel Employee
    You can set "802.11 Mode" to be 11ax (Channel Width: 20/40/80MHz) for radio profile to give WAX510D use the 11ax capability, while NWA5123-AC-HD still can use 11ac capability.
    FYI: In case you set "802.11 Mode" as 11ac, both WAX510D and NWA5123-AC-HD will use 11ac capability.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @Rimfire,
    There is no special suggestion for radio settings when having this type of mixed AP environment.
    Besides, we have series of FAQ about radio settings to get the high wireless performance as below
    1. Maximum output power
    2. WLAN Rate Control
    3. Limit legacy clients
    Although the FAQ for the Nebula version, you still can refer to the feature and the value of parameters for your configuration.
    Zyxel_Judy
  • Rimfire
    Thanks Judy!
    Great info.
    At ZyWALL Radio Profile. Is it a good idea to set "802.11 Mode" to be 11ax (Channel Width: 20/40/80MHz) when most of the APs are NWA5123-AC-HD? I mean, the AP is not actually a AX device.
  • Zyxel_Judy
    Zyxel_Judy
