Zyxel’s Wireless Solutions Wow India's Leading Hotel Clients
Zyxel_May
Zyxel_May Posts: 271 image  Zyxel Employee
First Comment Sixth Anniversary
edited February 2023 in Success Stories
Fortune Inn Riviera
“Everything has gone perfectly since the new network went into operation. The ease of management as well as the deployment of equipment across the center has made it easy for us to provide quality WiFi for every visitor, wherever they are.”
Mr. Giriraj
IT Manager, Fortune Inn Riveria
Summary
Fortune Inn Riveria aimed to provide the best customer experiences to visitors with top-notch hotel amenities, including lightning-fast WiFi to every guest. Therefore, it’s necessary to build a new wireless network from scratch. In search of an ideal solution, they approached some leading brands. After performance testing, the hotel management chose Zyxel as our products were able to fulfil their requirements. Our partner Communicate Networks played an important role here as they had great credibility associated with the client, and recommended our solutions. NWA1123ACv3 802.11ac Wave 2 Dual-Radio PoE Access Point was the first choice of the access point as its innovative design and commitment to “RF First” deliver high performance, reliable connections, and maximum coverage to every corner of the hotel, ensuring seamless connectivity for guests. Secondly, they deployed the NWA5123-NI Access Points. With non-stop wireless services, it provides reliable network connectivity for better business productivity. The GS1920HP-24v2 smart managed PoE switch provided power among the access points. Its user-friendly web-based GUI makes it easy to manage and set up the switch without learning complex CLI. Thanks to NebulaFlex, supported network devices are now managed and monitored over the cloud easily. New wireless infrastructure has shown satisfactory results to the management of the hotel as the clients have shared positive experiences regarding perfect wireless accessibility from everywhere.
Challenges
  • Establish a new wireless network infrastructure from scratch and ensure it could support a high number of clients
  • Enable easy and centralized network management of all network devices
Benefits
  • Smooth and stable WiFi creates great guest experiences
  • IT administrators can rapidly plan, deploy, and monitor networks
  • Remote visibility and monitoring allow real-time intervention anytime, anywhere
Products used
GS1920-24HPv2 Smart Managed PoE Switch
NWA1123ACv3 802.11ac Wave 2 Access Point
NWA5123-NI 802.11n Dual-Radio Unified Access Point
Download PDF for full story
